electric motor stator rotor air gap MRF approach for heat transfer coefficient
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   August 20, 2023, 23:15
Default electric motor stator rotor air gap MRF approach for heat transfer coefficient
Yakub
YAKUB A is on a distinguished road
hi,
I have been working in PMS motor. Heat transfer coefficient in the air gap between Stator and Rotor have found analytically using Taylor's corelation. To find using fluent I have tried MRF approach. A fluid region drawn around rotor and given frame motion to it. Even after 500 iteration net Energy flux don't reduce much(almost same) and h value is pretty much less.
Then I have given solid rotation instead of frame motion that also did not help. Somewhere in MRF I'm making problem I think, Please help for the issue.
YAKUB A is offline   Reply With Quote
Old   August 21, 2023, 04:29
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
check mesh quality
YAKUB A likes this.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   August 25, 2023, 00:37
Yakub
more than 10 million cells and mesh qualities are with in the limit
Old   August 25, 2023, 00:42
Yakub
Originally Posted by AlexanderZ View Post
check mesh quality
h of air gap in motor
Heat transfer coefficient - what is waht Stan FLUENT 28 December 29, 2021 16:29
Interphase mass transfer of a reaction cfx_ws1992 Main CFD Forum 0 May 15, 2017 21:42
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 01:27
Heat transfer coefficient CIN3X OpenFOAM Running, Solving & CFD 3 November 25, 2013 05:54
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
