electric motor stator rotor air gap MRF approach for heat transfer coefficient |
August 20, 2023, 23:15 |
Yakub
Rep Power: 3 |
hi,
I have been working in PMS motor. Heat transfer coefficient in the air gap between Stator and Rotor have found analytically using Taylor's corelation. To find using fluent I have tried MRF approach. A fluid region drawn around rotor and given frame motion to it. Even after 500 iteration net Energy flux don't reduce much(almost same) and h value is pretty much less. Then I have given solid rotation instead of frame motion that also did not help. Somewhere in MRF I'm making problem I think, Please help for the issue. |
August 21, 2023, 04:29 |
Alexander
Rep Power: 34 |
check mesh quality
best regards ****************************** press LIKE if this message was helpful |
August 25, 2023, 00:37 |
Yakub
Rep Power: 3 |
more than 10 million cells and mesh qualities are with in the limit
August 25, 2023, 00:42 |
Yakub
Rep Power: 3 |
h of air gap in motor |
Heat transfer coefficient - what is waht | Stan | FLUENT | 28 | December 29, 2021 16:29 |
Interphase mass transfer of a reaction | cfx_ws1992 | Main CFD Forum | 0 | May 15, 2017 21:42 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Heat transfer coefficient | CIN3X | OpenFOAM Running, Solving & CFD | 3 | November 25, 2013 05:54 |
