problems in the interaction between solid to fluid domains in fluent
Prev Previous Post   Next Post Next
Old   August 29, 2023, 05:39
Default problems in the interaction between solid to fluid domains in fluent
Jawa Tengah
alwan_hb is on a distinguished road
I'm doing a cooling simulation of an electric motor that uses a water cooling system. but it seems there is a problem between solid to fluid domain interactions. where when heat flux is applied to the solid domain and propagates to the fluid domain, the results are invalid. but when my inter-domain connection is broken and heat flux is applied to the fluid domain, the result becomes valid
Does anyone know how to maximize heat transfer between solid and fluid domains so that the Nusselt number results are valid?
alwan_hb is offline   Reply With Quote
heat flux., heat tarnsfer, nusselt number, solid fluid interaction
Fluid structure interaction with VOF method utilized in fluent? mxl9549 FLUENT 0 July 22, 2016 13:40
Fluid structure interaction with VOF method utilized in fluent? mxl9549 ANSYS 0 July 22, 2016 13:40
Fluid structure interaction with VOF method utilized in fluent? mxl9549 FLUENT 0 July 22, 2016 13:39
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 13:41
Solid and Fluid Domains in Fluent pvtschultz FLUENT 0 December 18, 2014 09:06
