problems in the interaction between solid to fluid domains in fluent |
August 29, 2023, 05:39 |
Jawa Tengah
I'm doing a cooling simulation of an electric motor that uses a water cooling system. but it seems there is a problem between solid to fluid domain interactions. where when heat flux is applied to the solid domain and propagates to the fluid domain, the results are invalid. but when my inter-domain connection is broken and heat flux is applied to the fluid domain, the result becomes valid
Does anyone know how to maximize heat transfer between solid and fluid domains so that the Nusselt number results are valid? |
August 29, 2023, 12:09 |
#2 | |
Kareem
Rep Power: 3 |
Please like the answer if it helped! Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured |
August 29, 2023, 19:06 |
#3 | |
Jawa Tengah
for example, on Re 500, the fluid outlet temperature is correct, but the wall temperature is still wrong, what should be 109 C, I got 138 deg C instead, so the Nusselt value should be 12, I got 5 instead. if each domain has a coupled wall and heat transfer has occurred, then where might the problem occur? for the record I've tried smoothing the mesh for the fluid domain |
heat flux., heat tarnsfer, nusselt number, solid fluid interaction |
Fluid structure interaction with VOF method utilized in fluent? | mxl9549 | FLUENT | 0 | July 22, 2016 13:40 |
Fluid structure interaction with VOF method utilized in fluent? | mxl9549 | ANSYS | 0 | July 22, 2016 13:40 |
Fluid structure interaction with VOF method utilized in fluent? | mxl9549 | FLUENT | 0 | July 22, 2016 13:39 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
Solid and Fluid Domains in Fluent | pvtschultz | FLUENT | 0 | December 18, 2014 09:06 |
