September 24, 2012, 07:52 |
Heat Transfer in Fluidized Beds
Musango Lungu
Rep Power: 14 |
Dear Friends,
I am using Fluent to model Heat transfer in a fluidized bed without reaction. I have enabled the energy equation under MODELS tab and have given the initial temperatures of the solid and gas which are 353 and 313 respectively i n the SOLUTION INITIALIZATION tab. The operating temperature of the reactor has been set to 353K under the OPERATING tab. However after running the simulation I have failed to get a plot of the temperature gradient in the fluidized bed, i.e temperature versus bed height. Where have I gone wrong? Waiting to hear from your suggestions. |
September 25, 2012, 11:14 |
#2 | |
shoeb khan
Rep Power: 14 |
Them patch the solid temp with 353K. And switch on the rans marshal law. Thne try it it will work |
September 7, 2023, 01:44 |
Chhotelal
Rep Power: 2 |
I also tried to solve it but I didn't get the solid temperature after the simulation right.
I followed the same procedure, for heating, I used a gun equation in the interface heat transfer between the phase, and before the initialization, I defined the solid temperature 353 and gas temperature 353, and after that patched the solid temperature 353 K. could you tell me where I am doing wrong? |
Heat transfer from a heated plate using fins | pathakamit | FLUENT | 1 | April 30, 2013 04:07 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
