November 14, 2023, 01:50 |
Convergence in a supersonic intake
Adithya Ajay
Rep Power: 2 |
Hello there,
Hope all are doing well, I will directly jump in to the problem My simulation of supersonic intake is not converging after a certain limit. Instead its oscillating. I know shock wave boundary layer interactiuons has inherent unsteadiness associated with it , so the residulas may oscillate while doing steady state analysis. But is there any way to reduce the residuals bit more? In some cases, after oscillating for long iterations, temparature is getting limited by fluent. I made temparature contour and found that I am having extremely high tempearture outside my intake ( on the tip of external domain). Why this happens? Images are attached here 1. Residual values after detecting divergence due to excessive temperature change. 274K Residuals (Divergence detected).png 2. Temperature contour after divergence detected Excessive temperature change 2.png My mesh is very fine inside the intake !! |
November 14, 2023, 18:23 |
Alexander
Rep Power: 34 |
that's because of mesh
best regards ****************************** press LIKE if this message was helpful |
November 15, 2023, 08:13 |
Please elaborate
Adithya Ajay
Rep Power: 2 |
Is it because of mesh inside my intake or outside ( external domain). Min orthogonal quality is 0.9 , Max skewness is very less , but Max aspect ration is in the range of 100. Another thing I noticed on the mesh is : since I used stretching in Y direction to have Y+ 1, on the top side of the external domain cells are stretched perpendicular to flow direction.
convergence check, supersonic internal flows, temperature limited |
Convergence issues in Supersonic flow | Alpha_Ashwin007 | FLUENT | 4 | July 6, 2023 22:26 |
Supersonic Convergence | beschadigunc | Main CFD Forum | 3 | June 2, 2022 07:36 |
Can't get convergence in subsonic nozzle | Nicola_Fontana | SU2 | 3 | December 21, 2021 08:01 |
Convergence problem - intake manifold | Nfcgfm | STAR-CCM+ | 12 | April 7, 2010 20:39 |
Supersonic convergence in density based solver | Charles | FLUENT | 0 | May 10, 2008 17:55 |
