January 5, 2024, 09:39 |
Porous zone
Rep Power: 4 |
I have a plate with holes in it modeled as a porous zone. It cannot be alligned by x, y or z -axis. I specified the direction vector (perpendicular on the surface of the plate). So I specified the flow resistance of the plate in the direction of this vector. Should I specifiy the flow resistance in the other two directions (so in the plane of the plate) as infinite or zero? Since no fluid can flow in these directions (inside de plate), should it be infinite? Thanks. |
January 8, 2024, 10:58 |
Rep Power: 5 |
Hi Klavoir
In the case of a perforated plate the fluid cannot move in those directions, so your idea seems correct. I would set a resistance value of many orders of magnitude higher than that of the main direction. However, in the case of perforated plate, I prefer to use the porous jump BC: it 's more robust and improves convergence. |
January 9, 2024, 02:47 |
Rep Power: 4 |
I agree, a porous jump is the preferred option here. Thanks for your reply. |
[Commercial meshers] Problem with Mesh conversion from FLUENT Meshing to OpenFOAM | mn17jyf | OpenFOAM Meshing & Mesh Conversion | 3 | November 1, 2023 09:49 |
Illegal cell label -1, fluent3DMeshToFoam | BenGher | OpenFOAM | 7 | October 10, 2023 00:02 |
PEMFC tutorial case problem | Suleyman41 | FLUENT | 2 | July 15, 2023 11:16 |
Averaging over iterations for steady-state simulation | CFD student | Fluent UDF and Scheme Programming | 8 | September 22, 2022 03:39 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
