full simulation of an aircraft with propeller effect
Old   June 17, 2010, 10:25
Question full simulation of an aircraft with propeller effect
kdrbrk's Avatar
Burak
kdrbrk is on a distinguished road
Hi all,
I searched the forum but no clear answers.
In order to simulate an aircraft with a propeller at the front (let's say it is a cessna 172):
In gambit:
(1)Can I simulate the propeller by a circular zero-thickness surface?
(2)If yes, should I split the volume with that surface?
(3)Which boundary condition must be given to that surface?
In fluent:
(4)With that boundary condition given in gambit, during steady state analysis, will it suck the air in front of the propeller and give it back with much more velocity/pressure?
(5)Can I give the rotating effect of air after the propeller?
Thanks in advance.
Burak
kdrbrk is offline   Reply With Quote
Old   June 17, 2010, 10:47
Kamil Sobczak
KamilSobczak is on a distinguished road
In gambit:
- Yes you can.
- This is correct operation.
- Fan will be good.
In fluent:
- In b.c. panel you can input value of constant pressure jump - Force generated by propeller divided by area of propeller surface.
- Default option in fan b.c. panel allows some swirl velocity but I don't understand how this works. So I input udf function to simulate rotating velocity.
But if your model is a simplification of propeller by surface I'm not seeing a point to include rotating effect in a simulation.
KamilSobczak is offline   Reply With Quote
Old   June 18, 2010, 01:29
kdrbrk's Avatar
Burak
Hi Kamil,
Thanks for your reply.
I will try it as soon as possible.
By swirling effect, I just wondered if I can see the swirling air hitting to the vertical stabilizer. This was just for fun
Old   January 17, 2024, 03:08
Venkat
Venkatakrishnan is on a distinguished road
I need to do this type of simulation where i need to calculate thrust and lift by transient analysis in ansys fluent. Can you help me to find how to proceed with it? i separated propeller from aircraft and gave cylinder enclosure for propeller and box enclosure for entire aircraft and propeller. Then i boolean subtracted the propeller from the cylinder enclosure and aircraft from box enclosure and cylinder from box enclosure with retain body of propeller. But how should i give constrain ?
I use transient solver with SST k omega, coupled solver and frame motion for rotating propeller which is not in origin of the coordinates.
I amgeting wrong results. what should i do?
Venkatakrishnan is offline   Reply With Quote
a propeller 2 way fsi kantored CFX 9 April 11, 2007 14:51
simulate a tank equipped with propeller inside aloha5i CFX 0 October 15, 2005 15:56
Propeller thrust at diff. advance ratio (CFX 5.7) Zoltan CFX 9 April 27, 2005 08:23
Fire simulation using FDS from NIST Jens Main CFD Forum 1 January 22, 2004 01:53
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 10:06
