Pump Curve from Simulation Differs Significantly from Test Curve
Old   February 14, 2024, 03:33
Default Pump Curve from Simulation Differs Significantly from Test Curve
Seckin Aker
jambi is on a distinguished road
Hello everyone,
I am currently engaged in simulating a centrifugal pump using Fluent. However, the curve derived from the simulation significantly differs from the one obtained in the experimental setup.
The boundary conditions are as follows:
Pressure inlet: 1 atm
Pressure Outlet: between 5 and 13 bar
Pump speed: 3000 rpm
I am implementing Frame Motion for the rotating part and reading the volumetric flow rate of the pump as a result.
The maximum pressure of the pump is 13 bar. Consequently, the simulation results match perfectly with the test results at 13 bar. However, as the pressure drops to 5 bar, the simulation results diverge from the test results, as depicted in the image.
My initial consideration is cavitation. Therefore, I activated the cavitation model, but it did not alter the results. Subsequently, I thought that surface roughness might influence the solution. Unfortunately, this did not yield a significant difference.
The suction height is 3 m. I also attempted a simulation with a reservoir located 3 meters below the pump, but this approach did not produce satisfactory results either.
If anyone among you has encountered a similar problem or has any ideas, I would appreciate your assistance. Thank you.
jambi is offline   Reply With Quote
centrifugal pump, fluent
Defining Boundary Conditions Dictated by a Pump Curve robtheslob FLUENT 5 December 2, 2014 14:30
Assistance in Vacuum pump simulation enr_venkat CFX 5 November 20, 2012 11:50
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
