Pump Curve from Simulation Differs Significantly from Test Curve |
February 14, 2024, 03:33 |
Seckin Aker
Hello everyone,
I am currently engaged in simulating a centrifugal pump using Fluent. However, the curve derived from the simulation significantly differs from the one obtained in the experimental setup. The boundary conditions are as follows: Pressure inlet: 1 atm Pressure Outlet: between 5 and 13 bar Pump speed: 3000 rpm I am implementing Frame Motion for the rotating part and reading the volumetric flow rate of the pump as a result. The maximum pressure of the pump is 13 bar. Consequently, the simulation results match perfectly with the test results at 13 bar. However, as the pressure drops to 5 bar, the simulation results diverge from the test results, as depicted in the image. My initial consideration is cavitation. Therefore, I activated the cavitation model, but it did not alter the results. Subsequently, I thought that surface roughness might influence the solution. Unfortunately, this did not yield a significant difference. The suction height is 3 m. I also attempted a simulation with a reservoir located 3 meters below the pump, but this approach did not produce satisfactory results either. If anyone among you has encountered a similar problem or has any ideas, I would appreciate your assistance. Thank you. Ekran görüntüsü 2024-02-14 110757.png |
centrifugal pump, fluent |
Defining Boundary Conditions Dictated by a Pump Curve | robtheslob | FLUENT | 5 | December 2, 2014 14:30 |
Assistance in Vacuum pump simulation | enr_venkat | CFX | 5 | November 20, 2012 11:50 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found | piprus | OpenFOAM Installation | 22 | February 25, 2010 13:43 |
Problems in compiling paraview in Suse 10.3 platform | chiven | OpenFOAM Installation | 3 | December 1, 2009 07:21 |
