inlet condition for 3D simulation
Old   February 27, 2024, 03:51
Default inlet condition for 3D simulation
eddy
tjwldhks79 is on a distinguished road
I am conducting a drag coefficient simulation for a cylinder in three dimensions.
I am referencing a paper for the simulation.
Specifically, I am applying potential flow conditions at the inlet.
Is applying a condition at the inlet where the flow has a specific velocity vertically from the surface different from the usual practice of having a velocity perpendicular to the inlet surface?
Considering the inlet condition where the velocity is perpendicular to the surface, wouldn't there be some nonzero rotation since the flow is not purely potential?
Even if they are different, would it significantly impact the Large Eddy Simulation (LES)?
I am calculating the drag coefficient from turbulent flows.
Thank you.
tjwldhks79 is offline   Reply With Quote
Pressure boundary condition for inlet with opening AS_Aero CFX 4 August 4, 2020 07:30
2D rotating detonation simulation - UDF inlet BC Tianxu FLUENT 10 July 27, 2020 02:28
Boundary condition confusion. Engine exhaust manifold ventilation. UPengineer Main CFD Forum 1 July 12, 2016 17:53
Pressure Inlet Boundary Condition Issue zoeburton1987 FLUENT 0 May 15, 2012 09:20
Boundary condition setting regarding turbine simulation using CFX Lacerlacer CFX 11 March 12, 2012 09:32
