is there a theoretical formula to verify pressure drop |
February 24, 2024, 09:45 |
Williams
Rep Power: 10 |
Dear everyone!
I used fluent to calculate the pressure drop inside a thin circular tube. My doubt is how the pressure drop is calculated? How do I know if the calculation is accurate and is there a theoretical formula to verify it?Thank you inadvance! gearman |
February 24, 2024, 11:46 |
Lorenzo Galieti
Rep Power: 12 |
I would look to use the usual moody chart, see https://en.wikipedia.org/wiki/Moody_chart. It works
February 24, 2024, 21:44 |
#3 | |
Williams
Rep Power: 10 |
February 25, 2024, 06:56 |
Lorenzo Galieti
Rep Power: 12 |
just do the case with zero roughness.. It's the smooth pipe curve in the moody diagram
February 26, 2024, 20:31 |
Williams
Rep Power: 10 |
Dear LoGal!Thank you for your reply!You mean to do the case with zero roughness to compare the result with the smooth pipes on the Moody diagram?But if the pipe I'm simulating is rough, how do I set the roughness in the fluent and compared with the rough tube in the moody diagram?
February 27, 2024, 00:52 |
Lucky
Rep Power: 66 |
There is no general rule for setting the roughness height. There isn't even a definition for what the roughness height even is. Roughness functions are developed by blatantly assuming that Nikuradse's law of the wall holds via circular logic. You find an equivalent roughness function by fitting the pressure drop and not the other way around. You can't predict the pressure drop unless you already know the roughness height and you can't know the roughness height unless you've measured the pressure drop.
February 27, 2024, 08:47 |
#7 | |
Erik
Rep Power: 23 |
Pressure Drop Measuring Problem | engineerm | Main CFD Forum | 4 | June 16, 2023 04:31 |
viscosity udf don't use correct temperature and strain rate | rezvani | Fluent UDF and Scheme Programming | 8 | May 27, 2021 05:40 |
PorousSimpleFoam with double pressure drop | Pyrokrates | OpenFOAM Running, Solving & CFD | 0 | April 28, 2021 08:36 |
Polydispersed phase pressure drop with drop size | Laksh | CFX | 1 | June 8, 2017 18:56 |
Pressure drop of valve with valve opening of 30% | elogesh | Main CFD Forum | 2 | January 5, 2007 12:30 |
