need help to create the geometry of a J-shaped airfoil in two dimension
Old   March 25, 2024, 11:39
Default need help to create the geometry of a J-shaped airfoil in two dimension
sourena
sourena14714 is on a distinguished road
hi
In ansys design modeler:
By using the curve from points command, I create two curves and then i close the open ends with the line from points command. So far, everything is correct(image 1), but when I create suface from the edges ,the curves breaks at several points(image 2).(I import the sketch from solid works too but I faced the same problem too).anyone could help me please?
sourena14714 is offline   Reply With Quote
[blockMesh]: problem create a wedge geometry mn14cat OpenFOAM Meshing & Mesh Conversion 1 August 3, 2022 10:34
Angled Airfoil Geometry Problem pharva Main CFD Forum 0 March 29, 2022 15:05
Geometry of RAE2822 airfoil Abolfazl_cfd Main CFD Forum 0 April 20, 2021 05:54
Ffd_control_point_2d feiyi SU2 4 September 30, 2019 12:42
High drag for airfoil compared to XFOIL and wind tunnel data Ry10 SU2 15 October 30, 2016 17:27
