Art
Rep Power: 5 ![]() |
Hello everybody!
I'm trying to simulate air movement in 2D. There is an external fixed cylinder and an internal rotating one, as well as two channels (top and bottom) for pumping air. The geometry, shaft speed and mass flow of air that enters through the shaft are known. The question is whether it is possible to simultaneously “apply” the Rotating wall and Mass-Flow-Inlet conditions to the inner cylinder (modeled so that air flows evenly, as if from the shaft (inner cylinder))? Or are there any other ways to solve the problem? https://ibb.co/4RvbJN7 - Picture of my geometry Thank you, I will be glad for any help! preview.png |
fluent, mass flow inlet, rotating boundary, shaft |
reverse flow in centrifugal fan blades | kalm | CFX | 20 | December 2, 2023 06:25 |
axial compressor mass flow convergence issue | jyotir | SU2 | 4 | November 24, 2021 06:03 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Combination of mass flow inlet and pressure inlet boundaries | MrStuebb | Main CFD Forum | 0 | January 6, 2011 09:59 |
Mass Flow Inlet with Velocity specification | bernarde | STAR-CCM+ | 1 | December 3, 2009 23:13 |
