Bad quality mesh
Old   March 26, 2024, 11:43
Default Bad quality mesh
Donald_Wu is on a distinguished road
I am doing a CFD wind tunnel test for a front wing geometry on Ansys fluent meshing for my final year project.
I have been trying to get the minimum orthogonality to be 0.1 or above but can't seem to be able to increase it much above 0.01. This problem occurred when inflation layer was added.
Inflation Layer conditions:
  • Uniform
  • Growth rate: 1.1
  • Number of layers: 20
  • First Height: 0.000016
Other conditions:
  • Body of influence: Mesh size 0.1m
  • face meshing on the front wing geometry: Mesh size 0.005m
  • Poly-hexcore used
Any help will be much appreciated.
Thank you
Donald_Wu is offline   Reply With Quote
Old   March 27, 2024, 01:58
siw
Stuart
siw will become famous soon enough
Most likely that the aspect ratio of the elements is too high. Presumably, you've calculated that first layer height based on a required y-plus value.
As a test, change to Smooth Transition for 5 layers (defaults). Is that OK? If you now increase the number of layers (without changing anything else) how does the element quality drop?
Watch these: https://courses.ansys.com/index.php/...undary-layers/
siw is offline   Reply With Quote
Old   March 27, 2024, 10:52
Yes, the first layer height is based on a required y-plus value.
Number of layers, Min Orthogonality
5, 0.1615
7, 0.1064
10, 0.0963
13, 0.0638
15, 0.0278
17, 0.0383
20, 0.0096
Thank you
Old   March 28, 2024, 03:26
siw
Stuart
Did you try the Smooth Transition method?
However, my guess would be that with the lowest height first layers (thus highest aspect ratio) then a slight distortion of the high aspect ratio adversely affects the minimum orthogonal quantity. Then then only way to reduce the aspect ratio of the first element is to decrease the surface element size on the regions of concern. Can you put a local face sizing (maybe you need to split the face in SpaceClaim and put in in a Names Selection aka Group in SpaceClaim, and see how that affects the quality metric.
Old   March 28, 2024, 23:29
Yes, I did try Smooth Transition.
I tried decreasing the surface mesh size at the affected region and the orthogonality increased.
Thanks for helping!
[snappyHexMesh] High quality mesh for wind in complex urban environment ziboaa OpenFOAM Meshing & Mesh Conversion 1 January 12, 2021 15:33
[ICEM] Bad Quality Hybrid Mesh External Flow tim13 ANSYS Meshing & Geometry 0 March 8, 2020 02:22
[snappyHexMesh] very bad quality snapped mesh federicabi OpenFOAM Meshing & Mesh Conversion 18 September 26, 2018 10:33
[ICEM] The pre-mesh quality is very good but the mesh quality is bad lnk ANSYS Meshing & Geometry 5 July 30, 2012 14:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
