Help With ANSYS Fluent Data Analysis
Old   April 10, 2024, 12:38
Default Help With ANSYS Fluent Data Analysis
Oliver Schneck
oliverschneck is on a distinguished road
Hi there,
I am new to CFD and ANSYS Fluent. I am trying to model a 2D periodic system. I plan on using MATLAB for the data analysis, so I am doing this by doing file->export->solution data. I am trying to look at the static pressure at the walls throughout the period. In the solution data, there is a data column for 'Static Pressure' and a column for 'Periodic Static Pressure' and they produce different results. I was wondering if someone could explain what the difference is between them and which one I should use for my application. Also, if you could point me in the direction of a help page that explains what all of the data exports reoresent in more detail, that would be great.
oliverschneck is offline   Reply With Quote
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 21:00
[Commercial meshers] Problem with Mesh conversion from FLUENT Meshing to OpenFOAM mn17jyf OpenFOAM Meshing & Mesh Conversion 3 November 1, 2023 09:49
Hydrodynamic analysis of submarine model with ANSYS FLUENT? Sovereignty ANSYS 0 January 20, 2019 18:36
Ansys Fluent analysis of heat exchanger MStudent FLUENT 2 April 20, 2015 08:40
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
