Divergence detected in AMG solver: temperature |
April 9, 2024, 01:03 |
minjeongkim
Rep Power: 2 |
I am currently analyzing the fluid flow field of a multi-nozzle in three dimensions. However, the following error keeps occurring.
Divergence detected in AMG solver: temperature absolute pressure limited to 5.000000e+10 in 32400 cells on zone 2 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2150 cells Divergence detected in AMG solver: temperature Divergence detected in AMG solver: temperature Divergence detected in AMG solver: temperature Error at host: floating point exception ===============Message from the Cortex Process================================ Compute processes interrupted. Processing can be resumed. ================================================== ============================ Error: floating point exception Error Object: () Error at Node 2: floating point exception Error at Node 0: floating point exception Error at Node 1: floating point exception Error at Node 3: floating point exception Error: floating point exception Error Object: #f mesh quality is ------------------------------------------ Skewness min 2.5942e-07/max 0.40638 aspect ratio min1.0015/max 3.346 orthogonal quality min 0.84878/max 1. ------------------------------------------ I need advice. please help me.. thank you |
April 9, 2024, 03:02 |
Marcin
The error message "Divergence detected in AMG solver: temperature" in Ansys Fluent indicates that the solver is having difficulty converging on a solution for the temperature field. Here are some steps you can take to address this issue:
**Understanding the Errors:** * **Limited Absolute Pressure:** The message "absolute pressure limited to 5.000000e+10 in 32400 cells on zone 2" suggests that the pressure values in some cells (zone 2) are reaching a very high limit. This could be due to an incorrect pressure boundary condition or a physical inconsistency in your model. * **Limited Turbulent Viscosity:** The message "turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2150 cells" indicates that the turbulent viscosity is being limited in some cells. This could be happening due to very high or low velocity gradients in those cells. **Troubleshooting Steps:** 1. **Check Boundary Conditions:** Double-check your pressure boundary conditions for zone 2. Ensure they are set correctly and don't lead to unrealistic pressure values. 2. **Refine Mesh:** A coarse mesh can sometimes lead to convergence issues. Try refining the mesh, particularly in areas with high pressure gradients or complex geometry. 3. **Relaxation Factors:** Adjusting relaxation factors for temperature, pressure, and other relevant variables can sometimes help the solver converge. Start with smaller values and gradually increase them. 4. **Under-Relaxation:** Enable under-relaxation for temperature and pressure. This helps the solver take smaller steps towards the solution during each iteration, potentially avoiding divergence. 5. **Solver Initialization:** Try initializing the solution from a simpler case or a previous converged solution (if available). 6. **Solver Settings:** Experiment with different solver settings like convergence criteria and residuals targets. 7. **Model Geometry:** Review your model geometry for any inconsistencies or sharp corners that might be causing numerical problems. 8. **Material Properties:** Ensure your material properties for temperature and other relevant fields are entered correctly and within reasonable ranges.
Quick Tips and Tricks, Tutorials FLuent/ CFX (CFD) https://howtooansys.blogspot.com/ |
April 9, 2024, 03:23 |
Thank you for the advice.
#3 | |
minjeongkim
Rep Power: 2 |
April 9, 2024, 03:36 |
Marcin
probably YES
April 10, 2024, 07:30 |
Lorenzo Galieti
Rep Power: 12 |
In my experience, the only thing makes fluent crash is a bad mesh. Unless you are simulating really complicated physics such as multiphase/combustion/similar.
divergence of temperature, fluent error! |
divergence detected in AMG solver: momentum | sudhakar | FLUENT | 41 | January 23, 2024 03:56 |
Population Balance Modeling (PBM) - Ansys Fluent | chittipo | FLUENT | 164 | November 18, 2023 11:54 |
Jet impingement cooling error - Divergence detected in AMG solver: temperature | riquelme | FLUENT | 0 | December 30, 2019 07:19 |
Divergence detected in AMG solver: temperature | otubaba | FLUENT | 7 | October 29, 2013 08:39 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 11:34 |
