I am a beginner and I need simple guidance.
Old   April 17, 2024, 14:51
Post I am a beginner and I need simple guidance.
Ertugrul
Aeroma is on a distinguished road
Hello everyone. I need to simulate CD nozzle for MACH 3.5 and I will be using the profile from an existing engine simulation for the nozzle inlet parameters however this simulation is made for Mach 2. I need to change the Mach calue and check the fuel injection ratio. Under inlet boundary conditions, there is gauge pressure and Mach number. I changed only the mach number there and then i changed the mach number at reference values. However, during at the initialisation, the value was 642 m/s (something like that) which ch is around Mach 2.3. Should I change it there as well. I am a bit lost because I am a beginner AND trying to work on an existing data file. I would really appreciate your guidance. I am doing this for my thesis and after figuring out the setup, i need to simulate the nozzle with different half angles for about 12 times and i am really, really short in terms of time. Also, i am using 2024 R1
Aeroma is offline   Reply With Quote
ansys, fluent, high mach number, set up
Guidance for a complete CFD beginner in MATLAB Vishal.Sethi OpenFOAM 3 November 23, 2020 15:35
Simple example in TUI for beginner GG80 Fluent UDF and Scheme Programming 0 February 8, 2013 14:29
Simple Beginner User Question on 'geometry' scottimus FLUENT 5 March 27, 2012 13:17
SIMPLE Algorithm - Questions from a Beginner Emre Turkoz Main CFD Forum 8 August 13, 2010 00:21
Beginner question OddEven Decoupling in SIMPLE Solver brooksmoses OpenFOAM Running, Solving & CFD 2 November 9, 2005 19:38
