April 18, 2024, 09:34 |
solar load calculation
ali
It is the first time I use ansys fluent and I have an issue when I calculate solar load for a cubic building (base case) as a starting point. it is just a 4 walls building. I followed some videos in youtub where expliain well the steps but for any reason that I missed I ger zero solar load in all facades. I also checked forums with similar error but old post link related to this error are corrupted unfortunately. i defined - model- solar ray tracing - materials for walls - concrete -boundary conditions for each wall- material, type, thermal conditions,.. opaque and participate in solar ray tracing -inicialization - computes from all zones -contour -- select heat flux and wall fluxes basically the steps of the videos. I have attached the model link I hope you can download it and tell me what i do wrong. so my questions are 1- Why d I get zero solar load on the facade? 2- some videos they add a outside air domain element apart from the building, what is the goal of it? thanks in advance https://drive.google.com/file/d/1Ioh...usp=drive_link |
To simulate lamp bulb effect using solar load model | seojwceo | STAR-CCM+ | 2 | May 16, 2022 07:25 |
Solar load with view factors not giving qr and T variations | B_R_Khan | OpenFOAM Running, Solving & CFD | 1 | December 24, 2021 06:55 |
ray-tracing solar load vs DO radiation model | nima_nz | FLUENT | 4 | August 26, 2021 09:22 |
fresher in heat transfer and solar load model | itsme_kit | FLUENT | 4 | January 11, 2016 12:12 |
Radial Load calculation | pump_passion | CFX | 3 | March 31, 2010 17:51 |
