Weird Behaviour of Residuals in Transient simulation
Old   May 12, 2024, 08:11
Default Weird Behaviour of Residuals in Transient simulation
Ashwin
Alpha_Ashwin007 is on a distinguished road
Hi, I'm trying to simulate supersonic flow (M=1.6) through a duct with shocks, first in steady state, then as a transient simulation by varying outlet pressure.
I was able to get a good and stable steady-state solution only after using high-speed numerics. After that, I tried to run a transient simulation and used an udf to vary the outlet pressure sinusoidally. But I'm noticing a bizarre behaviour of residuals.
During each iteration, it is continuously increasing. The timestep I used is 1e-6 (20 inner iterations), which I think is small enough for the frequency of oscillations of the outlet pressure (1000hz).
I am using the density-based solver, second-order discretization, second-order time stepping, high speed numerics, CFL = 0.9, k-w sst model.
I have attached a picture of the residuals and the dp/dt contour which shows some weird distortions, kindly let me know if anyone has any ideas on how to fix this.
Thanks
Alpha_Ashwin007 is offline   Reply With Quote
residuals keep horizontal when doing transient simulation calf.Z OpenFOAM Running, Solving & CFD 0 September 3, 2019 08:51
Transient simulation : Static temperature and time averaged static temperature saisanthoshm88 CFX 4 July 4, 2013 02:18
the problem of my transient simulation "Floating point exception: Overflow " alloveyou CFX 15 November 22, 2012 11:14
Beginning a Transient Simulation Norflow CFX 2 October 7, 2011 00:38
Resume Transient simulation HMR CFX 1 June 28, 2011 21:13
