pressure field
Old   January 25, 2000, 05:57
Default pressure field
Ieria Giovanni
Ciao, I'm a student of mechanical engineering, I'm developing a thesis on CFD for ship.I'm using Fluent for a viscous analysis of a Wigley hull. I've noted that Fluent excluded hydrostatic head rho*g*z from the pressure calculation when the density is uniform (user's guide 6-18). If this is unimportant for incompressible gas,it can be a great error for my type of analisys? How am I able to overcome this problem? Maybe by user defined functions (I don't know to compile it), or by a boundary condition? Can this problem invalidate viscous resistance calculation? If you can, send to me a possible solution. Thank you very much.
Giovanni
Old   January 25, 2000, 11:20
Default Re: pressure field
John C. Chien
(1). Interesting question. Can a ship still float without rho*g*z ?
Old   January 28, 2000, 05:51
Detlef Schulze
Hi, although it appears as if the hydrostatic pressure is not included in Fluent it actually is! The trick is, that p_hyd is excluded from the pressure-calculation and included in the bodyforce term. That is alright, since p_hyd = rho * g * h it does not change in an incompressible flowfield. If you want to display p_hyd for postproc-reasons than just define a custom-field function under Fluent's "Define"-Menue.
Greetings Detlef
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
How to get Pressure field from velocity field qunwuhe@hotmail.com Main CFD Forum 4 October 14, 2007 07:38
order of magnitude analysis atit koonsrisuk Main CFD Forum 3 July 27, 2000 11:59
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
