Modeling turbulence with Eulerian model
Old   March 9, 2000, 05:04
Default Modeling turbulence with Eulerian model
Eric OLMOS
Hello! I'm working on the simulation of bubble columns using the k-epsilon model. I wonder wether the added terms due to the dispersed phase in the transport equation are set by defaut when the eulerian approach is used. If true, to what corresponds the question:"Enable extra terms for k-epsilon?" in the control panel. In the same way, is the turbulent drag term set by default? Does someone know something about this ?
Thanks in advance! Eric O.
SimpleFoam case with SpalartAllmaras turbulence model implemented nedved OpenFOAM Running, Solving & CFD 2 November 30, 2014 22:43
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 09:02
KOmega Turbulence model from wwwopenFOAMWikinet philippose OpenFOAM Running, Solving & CFD 30 August 4, 2010 10:26
turbulence model and sol init_best practice sam Main CFD Forum 0 October 18, 2006 01:10
Sinclair Model + secondary turbulence Yi FLUENT 0 October 26, 2001 13:37
