Running Gambit as a batch job
Old   March 21, 2000, 23:59
Default Running Gambit as a batch job
Narayan
Hi Guys,
I have a basic question regarding Gambit. I want to know if it is possible to submit a job on GAMBIT, to run it in the background as a batch process. I am using a SGI system.
Your help will be highly appreciated.
-narayan
Old   March 22, 2000, 08:41
Default simulation of non-newtonian fluid
M.zhou
hi,
I want to know --Can Fluent simulate turbulent flow of non-newtonian fluid using such as k-e turbulent models? And how does it work?
thinks
M.zhou(zhougz@buct.edu.cn)
Old   March 22, 2000, 18:03
Default Re: simulation of non-newtonian fluid
Jennie
Hi! Mr Zhou,
Almost impossible!
Jennie
Old   March 23, 2000, 09:56
Default Re: Running Gambit as a batch job
Scott Gilmore
To run Gambit in "batch" mode, prepare a journal file (e.g., "test.jou"), then use the command
gambit test -in test.jou
Running fluent with udf in batch mode zonexo Fluent UDF and Scheme Programming 2 March 10, 2012 07:50
Gambit Running Error oxidising agent FLUENT 18 October 19, 2010 09:52
running gambit using xwin - 32 ashish FLUENT 0 February 13, 2007 11:36
Running Gambit under WinXP Christine FLUENT 15 August 18, 2005 15:03
running post batch fails Fabian CFX 0 June 27, 2005 07:30
