June 15, 2000, 13:10 |
UDF
Hi! I want to define a UDF for my problem. FLUENT 5.3 is here installed on windows 2000. Also I have visual C++ installed on my PC. Do I define a compiled or an interpreted UDF?
June 29, 2000, 05:24 |
Re: UDF
Check the Frequently asked questions for Windows NT page on the www.fluentusers.com website. It should have all the information you need. Also, you should check with Fluent as to whether windows 2000 is currently supported...I suspect it may not be as yet. In general, a compiled UDF will run much faster than an interpreted UDF. So if you already have the compiler, it might be worth using compiled rather than interpreted UDFs.
Regards, Malcolm |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
