combustion problem
Old   August 30, 2000, 15:17
Default combustion problem
cindy
Hi, I am using fluent5 to simulate a combustion process. The fuel is propane and another chemical material. I just tried to use the propane 2 step model to simulate the rich combustion, but the solution wouldn't converge.
For the initial condition, outlet boundary condition, I don't know how to set them. Can you give me any suggestion?
Also, I checked some literature for Westbrook's 2 step kinetic model of propane combustion, the Arrehnius parameters seem different from what are provided by Fluent model. I don't know whether I need to modify the Fluent number or not.
Thank you. Cindy
Old   August 31, 2000, 00:16
Default Re: combustion problem
Jin-Wook LEE
Dear Cindy
1. Convergence : For combustion analysis, I have met convergence problem, like you, for every case. However, I have overcomed the problem for most case, by re-generating grid-net, by adjusting under-relaxation parameters and so on. For example, under-relaxation parameters for species are set to be 1.0 by Fluent 5.x as default values. However, I could have good convergence by using default value ONLY for some case. I usually set lower values and increase slightly after couple of hundreds iterations and eventually to near 1.0. Poor grid-net is also one of source of convergence difficulty. If there is a region where (delx)i/(delx)i-1 >> 1. or <<1, it is very difficult to reduce residual values, especially for pressure residual. In addition, there might be many factors which cause convergence problem. As you might guess, convergence of higher order discretization scheme is more difficult than lower order scheme. RSM is more difficult than k-epsilon. Strong swirl which is generally accompanied to the combustion makes difficulty. So, I start from k-e to RSM(if required), from lower order to higher order, from weak swirl flow to higher swirl, sometimes from lower carlorific value to eventually higher(real) value and so on. You may need couple of try but I guess you should have fairly useful results.
2. Initial condition : I think that it's too difficult question. Unfortunately, I only rely on 'trial & error'.
3. Arrehnius parameters : Most codes, including Fluent, adopt slower rate among chemical kinetics controlled rate(Arrehnius type) and turbulent mixing controlled rate(eddy breakup type). As far as my numerical experience is concerned, sensitivity of Arrehnius parameters is fairly weak than eddy break-up parameters, especially for high temperature application. And, considering that Arrhenius parameters are determined by a kind of curve fitting from experiment of fuel, sometimes two(or more) euuations of a type, A*EXP(-E/RT), suggested by different researchers, are fairly similar even though A and E are different each other. So I recommend that, at first, compare the ploting of two curves, A1*EXP(-E1/RT) and A2*EXP(-E2/RT) by spread sheet calculation. Next, compare CFD results by using two different Arrehinus equations, while maintaining the law, R=min(R1,R2), where R1=rate of chemical kinectics controlled reaction and R2 is that of turbulent mixing controlled reaction. You might have similar results for many combustion application.
Sincerely, Jinwook
Old   August 31, 2000, 07:40
Henrik
Regarding Westbrook & Dryer's constants vs. FLUENT values: As far as I recall, Westbrook & Dryer used units of cm and mol, while FLUENT uses m and kmol - if exponents of fuel and oxygen concentration do not add up to 1, constants will be different, because pre-exponential factor is no longer dimensionless. I also think W & D used kcal/mol for activation energies instead of J/kmol - again there will be a difference in numerical values due to use of different units.
Regards,
Henrik
Old   September 1, 2000, 04:14
L. Li
i think you will overcome this if you don't use 2 step model. you can initialize the suitable value first. then iterate it.
when i use 2 step model in my combustion case, i still get the divergence result. i think fluent5.x is different with fluent4.x. maybe this is false.
good luck Li
Old   September 4, 2000, 18:54
Maurizio Barbato
Hallo,
what Henrik says is correct. Units used by W-D for the source depletion terms: d[C_3H_8]/dt = -A exp(-E/RT)[C_3H_8]^m [O_2]^n are gmole/(cm^3 s). Therefore the units for the preexponential term are:
A = (gmole/cm^3)^(1-m-n) 1/s and for the activation energy (the exponent has to be non dimensional) E = Kcal/gmole
Which can be easily converted to SI units then.
As far as I know A and E values implemented in Fluent for the one step chemistry are coherent with the W-D model. This is not the case for the two steps model.
Cheers
Maurizio
Old   September 4, 2000, 19:00
Maurizio Barbato
Hello again,
just a suggestion for the outlet boundary condition: set them as pressure boundary with gauge pressure value equal zero.
Cheers
Maurizio
hel (turbulent viscosity ratio limited) for supersonic combustion problem omar.2002bh FLUENT 2 September 5, 2012 11:04
Problem using EDM for combustion nakul FLUENT 1 August 11, 2011 05:01
A problem with combustion Luk Main CFD Forum 1 April 28, 2008 09:55
Combustion problem rupal CFX 0 April 21, 2008 05:29
problem in incomplete nonpremixed combustion muro FLUENT 0 September 28, 2007 06:54
