Flow Maldistribution
Old   September 21, 2000, 09:51
Default Flow Maldistribution
Sandeep
I need to quantify flow maldistribution in a vertical cylindrical geometry at a certain plane within the cylinder. I am interested in calculating standard deviation in vel. magnitude at a certain plane. How do i do this in fluent ?. Is there a way where in I can ask fluent to report vel. mag values at all nodes located at a certain plane
thanks in advance
Old   September 21, 2000, 11:21
Default Re: Flow Maldistribution
Angus Duncan
I'm not sure if Fluent has this capability- I would normally write out the plane profiles of interest (File>Write>Profile) and then analyse the data in a spreadsheet package.
Angus
Old   September 21, 2000, 14:59
Jonas Larsson
I'd do the following:
1. Define the surface I'm interesting in as an iso-surface of a constant grid-coordinate.
2. Use the surface-average function to compute the average velocity on that that surface.
3. Define a custom-field-function to compute the standard-deviation.
4. Use the surface-integral function to integrate up the custom-field-function defined in 3.
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
What is the difference between liquid reactive flow and gas reactive flow? James Main CFD Forum 6 May 15, 2009 12:14
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 07:40
Plug Flow Franck Main CFD Forum 3 September 4, 2003 05:57
