Supersonic flow over flat plate - best model
Old   September 29, 2000, 06:01
Default Supersonic flow over flat plate - best model
Chris Rand
I am trying to model the flow through various supersonic nozzles with the jet flowing over a flat plate. My main area of interest is the point of separation on the plate and also the shear stress distribution along the plate.
At the moment I am using the Realizable k-epsilon model, but is there a better model to use?
Thanks for your help.
Chris Rand
Old   September 30, 2000, 15:19
Default Re: Supersonic flow over flat plate - best model
John C. Chien
(1)."is there a better model to use?" I guess, there is always a possibility. But, you need to define the better model first. I mean, how do you measure the model to see whether it is better? I am sure that, if you try different models, you will get different results.
(2). So, why not pick another turbulence model, run the calculations, and let us know the results. If you have flow separation, then it is a good idea to use a low Reynolds number model. (vs wall function)
Old   October 2, 2000, 06:44
Chris Rand
Thanks I will try that.
Chris Rand
Old   October 3, 2000, 05:28
Chetan Kadakia
Why do you state that a low Reynolds number should be used if flow is found to separate? And why the wall function?
Old   October 3, 2000, 06:58
Jonas Larsson
Wall-functions are only valid in "well-behaved" boundary layers, ie the boundary layers should be attached, fully-turbulent and have a small streamwise pressure-gradient. If you have a complex flow with separations etc. the wall-functions give incorrect predictions and you should use a low-Re model.
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
Boundary Layer of Laminar Flow over a Flat Plate Blasius_Pohlhausen_Crocco Main CFD Forum 12 September 30, 2013 17:35
Supersonic flow over a flat plate and a blunt body. Maddy FLUENT 0 August 31, 2010 16:35
BIg BIg Problems....SUPERSONIC FLOW OVER A FLAT PL edison Main CFD Forum 7 October 11, 2005 09:34
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
