how to model a free surface
Old   October 12, 2000, 09:37
Default how to model a free surface
lr
hi; i am a new user of fluent5. I have some problem when i model the free surface of water flowing in a tank that is open to the atmosphere.( boundary condition,velocity distribution) . by the way, how can i give the the shape of surface as it is Thank You in advance!
Old   October 14, 2000, 06:17
Default Re: how to model a free surface
A.Hassaneen
I know how to do it in FIDAP but I'm not sure if they are using same idea in Fluent 5. Can anybody advise?
Old   October 16, 2000, 09:51
Sung-Eun Kim
FLUENT 4 and 5 offers a "free-surface capturing" scheme often referred to as Volume-Of-Fraction (VOF) scheme. In this method, FLUENT solves advection equation(s) for a scalar variable (volume fraction) that is a indicator of which fluid a field point is occupied by. The free surface corresponds to the iso-surface where the volume fraction is between 0 and 1 (normally 0.5 is taken).
FLUENT User's Guide has a detailed description of the method, boundary conditions, and some references.
Old   October 17, 2000, 06:36
lr
hi Sung-Eun Kim:
Thank you.
my email is : helloby@eyou.com
I need your help
sincerely:lr
Old   December 6, 2000, 14:22
Shoreh
As I understand your question is How can you solve a free surface problem by specifying the location of the free surface. In fact you do have the position of the free surface and you are not looking to compute it. All you need to do is to make your mesh in such a manner that the specified free surface shape is in fact one of your boundaries and then give it a symmetry boundary condition in Fluent. If you want to compute the position of the free surface, then you need to use the VOF (which stands for Volume of Fluid) approach of Fluent which is a volume tracking method and will in a very approximate sence compute the position of the free surface. OR you can get Fidap and use the ALE approach of Fidap and compute the shape with a very robust surface tracking algorithm.
Old   December 8, 2000, 07:51
lr
thank Shoreh:
All the problem seems simple to you. and the difficulty is solved in order . Your help is greatly appreciated. best regards.
lr
Linear analytical solution oto the 2D free sloshing water surface elevation bearcat Main CFD Forum 7 August 5, 2011 20:13
MULTIPHASE - FREE SURFACE & MIXTURE MODEL Aris FLUENT 3 April 28, 2009 11:46
gravitational force for free surface flow Jongtae Kim Main CFD Forum 1 July 2, 2000 11:57
Variable Density - Free Surface with FIDAP Vitaliy Pavlyk FLUENT 7 May 2, 2000 15:56
free surface model of pelton turbine bucket Mark Jones Main CFD Forum 0 April 10, 2000 08:20
