Velocity Inlet & LRN
Old   December 21, 2000, 13:40
Default Velocity Inlet & LRN
Jeff
1. How to set the arbitary velocity inlet B.C, i.e., the non-uniform velocity? Anyone who has some ideas is appreciated.
2. By the way, those who has used the Low-Reynolds-Number (LRN) k-e turbulence models. Could you tell me what is the corresponding references for (0) Abid? Is it k-t model? I found all references but this.
Thanks a lot!
Old   December 22, 2000, 00:16
Default Re: Velocity Inlet & LRN
Ashutosh Joshi
1) For this you can write a udf with random number genarator in C. May be multiply each random number with some constant to get higher velocity. Use this macro and hook at the inlet, I suppose.
regards
Ashutosh
User Defined Profiles, Swirl, Velocity Inlet saurus FLUENT 0 January 26, 2011 15:35
Unexpected difference between velocity / mass-flow inlet jpo FLUENT 8 December 10, 2010 07:20
[swak4Foam] Scale discrete inlet velocity profile with groovyBC cboss OpenFOAM Community Contributions 1 June 20, 2010 13:02
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 11:21
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
