Solution convergence
Old   February 19, 2001, 13:54
Default Solution convergence
nick
Being pretty much an amateur when it comes to using Fluent 5 is there any body who could asdvise me on ways in which i could get my solution to converge quiker. The analysis is of a 0015 airfoil in 2-d cascade using the RNG-k-epsilon model. Re nos of up to 0.5 million.
Old   February 19, 2001, 23:03
Default Re: Solution convergence
John C. Chien
(1). You should always try a coarse mesh solution first. (2). Something like a 30x30x30 mesh size would be a good starting point. (3). Once you have a converged solution, then you can try to get the mesh independent solution next.
Old   February 26, 2001, 12:41
Flav
I don't know what kind of initialization you use, but once you get a converged solution, you can interpolate the data (write), and then read this data file and interpolate the solution on another mesh. If you have to carry out calculations on geometries that do not vary two much from one to another, then this is time saving for the convergence, since the solution may not vary too much.
CFL Condition Matt Umbel Main CFD Forum 19 June 30, 2020 08:20
smoothSolver diverges - solution in using PBiCG solver? makaveli_lcf OpenFOAM Running, Solving & CFD 3 September 11, 2013 12:44
Does FOAM converge to exact solution in Laplace equation? santiagomarquezd OpenFOAM Running, Solving & CFD 0 March 26, 2010 07:52
Philosophy of implicit solution of different regions Louis Le Grange OpenFOAM 0 October 5, 2009 10:53
solution convergence problem anbuselvan FLUENT 1 January 18, 2009 04:00
