How define K and epslon for INLET?
Old   April 5, 2001, 21:32
Default How define K and epslon for INLET?
Harry Qiu
Dear everyone:
How to define K and epslon for INLET?
thank you
Sincerely, Harry.
Old   April 6, 2001, 11:13
Default Re: How define K and epslon for INLET?
manaf hasan
why you need to do that? the K & epslon is for the flow inside(interor) onley so you dont have to define K and epslon for the inlet onley .the K & epslon is one kind of modeling the turbelnt flow and should be fixed for all the fluid domain
Old   April 6, 2001, 11:30
Chinor
You need to specify inlet turbulence quantities. They are an essential part of defining a turbulent flow problem.
k=1.5(U I)^2
U=local velocity magnitude I=turbulence intensity
eps=[(Cmu^.75)*(k^1.5)] / l
Cmu=0.09 (for standard k-eps model) k=turbulent kinetic energy l=turbulent length scale
You can specify other inlet turbulence parameters in Fluent such as turbuelnt intensity & viscosity ratio. You are not limited to specifying k&eps.
Chinor
Old   April 6, 2001, 11:36
manaf hasan
thank you Chinor for this useful information can you forward to me the refrences that you get your equations from so i can read all the realted articels thanks again
Old   April 13, 2001, 16:16
Xiao Hu
k and e are rarely used directly. Instead, you have three more choices. If you have an internal flow, turbulence intensity and hydraulic diameter is your best choice. If you are soling an external flow, turbulence intesity and turbulence viscosity ratio is your best choice.
Epslon error. Samir Main CFD Forum 0 April 12, 2005 08:23
