dear friends,
who know how to copy the inlet surface to another surface by FLUENT 5 ? Thanks. Best regards, You |
What do you mean by copying the inlet surface to another surface? Do you want to copy the boundary condition or do you want to copy the mesh?
Hello Xiao Hu:
Thank you very much for your reply. The problem is: I use a periodic boundary condition to simulate a periodic flow (inlet and outlet is periodic). I save the periodic inlet+outlet profile in a profile file. In another case, I just need the inlet boundary condition for another flow field simulation. How can I separate the saved inlet+outlet profile into a inlet profile and a outlet profile? Thank you very much for your help. With best regards, You |
Since you are using periodic boundary conditions, the solution at your inlet and outlet are exactly the same. So, I don't think that it will make any difference if you use the profile the way it is. I do not really see the need to separate them.
Anyway, for your information, you can still separate them. Actually, the right term should be 'slit'. After finish your calculation for the periodic case, use the following command to slit the periodic face zone. Then you can write profiles for your individual inlet and outlet. /define/boundary-conditions/modify-zones>slit-periodic |
Hello Xiao Hu:
Thank you very much for your help. I will follow your suggestion to separate the periodic condition. With best regards, You |
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 04:58 |
Validation 12.1 vs 6.3, Difference in Reported Inlet Total Pressure | jola | FLUENT | 1 | May 5, 2011 14:33 |
Recover surface from surface mesh in IcemCFD | Jerry Tanner | CFX | 0 | August 20, 2008 12:48 |
user surface in post | xinzhangabc | CFX | 0 | February 24, 2005 06:29 |
may I use Pressure inlet Boundary as free surface? | duci | FLUENT | 0 | August 23, 2002 22:29 |
