inlet surface copy
Old   April 25, 2001, 08:44
Default inlet surface copy
you
dear friends,
who know how to copy the inlet surface to another surface by FLUENT 5 ? Thanks.
Best regards, You
Old   April 25, 2001, 13:48
Default Re: inlet surface copy
Xiao Hu
What do you mean by copying the inlet surface to another surface? Do you want to copy the boundary condition or do you want to copy the mesh?
Old   April 25, 2001, 14:28
you
Hello Xiao Hu:
Thank you very much for your reply. The problem is: I use a periodic boundary condition to simulate a periodic flow (inlet and outlet is periodic). I save the periodic inlet+outlet profile in a profile file. In another case, I just need the inlet boundary condition for another flow field simulation. How can I separate the saved inlet+outlet profile into a inlet profile and a outlet profile? Thank you very much for your help.
With best regards, You
Old   April 25, 2001, 16:07
Xiao Hu
Since you are using periodic boundary conditions, the solution at your inlet and outlet are exactly the same. So, I don't think that it will make any difference if you use the profile the way it is. I do not really see the need to separate them.
Anyway, for your information, you can still separate them. Actually, the right term should be 'slit'. After finish your calculation for the periodic case, use the following command to slit the periodic face zone. Then you can write profiles for your individual inlet and outlet.
/define/boundary-conditions/modify-zones>slit-periodic
Old   April 25, 2001, 16:18
Default thanks
you
Hello Xiao Hu:
Thank you very much for your help. I will follow your suggestion to separate the periodic condition.
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 04:58
Validation 12.1 vs 6.3, Difference in Reported Inlet Total Pressure jola FLUENT 1 May 5, 2011 14:33
Recover surface from surface mesh in IcemCFD Jerry Tanner CFX 0 August 20, 2008 12:48
user surface in post xinzhangabc CFX 0 February 24, 2005 06:29
may I use Pressure inlet Boundary as free surface? duci FLUENT 0 August 23, 2002 22:29
