gambit export
Old   April 27, 2001, 05:52
Default gambit export
olivier
Hi
I have problems to export a mesh (from Gambit) with periodic boundaries. I read an error message :mesh not created because of periodic boundaries faces problem
If I change the periodic boundaries in a symmetric bound, I have no problem to export this mesh.
Nota : periodic faces are linked
It would be very nice if someone could help me bye olivier
Old   April 27, 2001, 09:04
Default Re: gambit export
Xiao Hu
I am not sure what happen. But if you are sure that the mesh are exactly the same, then you can make periodic boundary in Fluent. The following command should help you make periodic boundary condition. /define/boundary-conditions/modify-zones>mp
Old   April 27, 2001, 09:12
Lanre
What version of Gambit are you using?
Anyway, export the mesh with the periodic zone as a symmetry zone, and the periodic shadow also as a symmetry zone (with a different label, e.g., symmetry.2).
1.Read your mesh into FLUENT 2. Open the Define-->Boundary Conditions... panel and check the zone IDs of your periodic and shadow zones (do this by selecting the zone label in the lefthand column and checking the ID field) 3. Using the text interface (click in the FLUENT console and hit the "enter" key) type:
grid <enter> modify-zones <enter>
4. In the modify-zones menu, execute the make-periodci command, i.e. make-periodic <enter>
Follow the prompts to enter the zone ID numbers of your periodic and shadow zones (another way to get the zone IDs is to type: grid modify-zones list-zones)
FLUENT should report back that "all #### faces match". If they don't you probably did not create your periodic meshes correctly in GAMBIT.
Old   May 2, 2001, 05:18
olivier
thanks a lot for your answer
That is the solution of my problem.
Regards
olivier
Old   May 9, 2001, 12:39
Flav
I have been told that with Fluent6 we should be able to make faces periodic, even if their meshes do not match.
export 2d model from solidworks to gambit bad080boy Main CFD Forum 2 April 29, 2011 14:31
mesh missing after export in gambit morteza08 ANSYS Meshing & Geometry 1 July 26, 2010 01:10
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Export data from GAMBIT to GAMBIT Sanjay Jain FLUENT 1 April 3, 2008 00:44
export or convert gambit mesh to CGNS zaidun FLUENT 6 April 20, 2006 04:48
