udf example
Old   May 13, 2001, 23:04
Default udf example
appleyy
Hi,I am learning to use UDF to model a velocity_inlet boundary condition where the velocity is dependent on the time.In the fluent help,there is a example named"unsteady flow in a tube",which is similar to my problem.But when I did as what it tells me,in compile step,the fluent said "error:sinusodial-v.c:line 1arse error".I don't know what it means and what shall I do. thank you for any help.
Old   May 15, 2001, 23:22
Default Re: udf example
Lanre
The UDF works as copied directly off their electronic documentation. Are you on UNIX or PC?
Old   May 30, 2001, 12:03
rafi friend
yea, sometimes i got that message too. but after i rewrite the function, or copy paste with other name, it's solved. just try.
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 07:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 22:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 21:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 04:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 04:01
