Boundary Condition?
Old   August 1, 2001, 14:08
Default Boundary Condition?
Rouham Ganji
Hi everyone,
I am trying to model the flow around a rocket The problem that I'm having is that I'm not sure what kind of boundary conditions I should be using.
I used a rectangle for the flow domain. When I ran the simulation at low speeds, I used velocity_inlet and pressure_outlet, which worked fine.
But for incompressible flows the fluent manual states that you shouldn't use velocity_inlet.
Any suggestions?
thanks
Old   August 2, 2001, 05:02
Default Re: Boundary Condition?
Alain
Use a pressure far field condition (riemann condition) for all your boundaries
Old   August 2, 2001, 12:13
Rouham Ganji
What if my flow domain is not too large (approx 3x rocket size) and I am using a symmetry plane?
with this setup I don't think I can use pressure far field on all boundaries.
NEED HELP
Thanks
Old   August 3, 2001, 06:18
Alain
The symetry condition can be used in conjonction with a pressure far field.
If your flow is compressible your domain is definitevly too small and you should use pressure far field.
If your flow is incompressible you can use velocity inlet / pressure outlet but I think that 3x caracterisitc size in all directionis a little bit small. You should have at last 10x or 20x in the flow direction depending on what you are looking for.
Best regards
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 12:26
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
