generate spring with GAMBIT
Old   August 17, 2001, 14:24
Default generate spring with GAMBIT
island
Hi!
Did anybody have experience to generate spring-volume having spiral geometry with GAMBIT? Is it difficult to generate such volume?
Thank you very much in advance.
Old   August 18, 2001, 03:46
Default Re: generate spring with GAMBIT
Jerry
Hi Island,
You can generate a spring volume by sweeping a face along a pro-defined spring curve. This is very easy to do in Gambit. To make the spring curve, you can
1), try write a simple programe to Gambit (Do-loop) to creat a serial of vertices and then link them to form the spring cruve; 2), prepare (x,y,z) data of the spring in 3 columns and save them as a txt file, then you can "import" the vertex data into Gambit. Quickly after that, link them and form to the spring curve.
Old   August 18, 2001, 09:40
max
you can use Msc.Patran or CFX-builder to generate the spring first,then export it to Gambit
[GAMBIT] how to generate orthogonal mesh using GAMBIT? ivanbuz ANSYS Meshing & Geometry 8 October 21, 2009 03:41
Use Gambit to generate 3D mesh ! ! ! yuanye FLUENT 0 June 3, 2008 22:03
Generate 3D PDF/other 3D view from Gambit Skander FLUENT 1 March 27, 2008 06:03
Can GAMBIT generate multi-block grid? superfool FLUENT 0 January 4, 2007 20:35
Gambit, how to generate figures? Jim Clancy FLUENT 2 July 21, 2006 07:44
