problem on DEFINE_DPM_OUTPUT
Old   September 30, 2001, 13:20
Default problem on DEFINE_DPM_OUTPUT
Xubin
I am now working on a discrete phase flow and like to export the velocity magnitude of gas along each particle trajectory. It seems that using DEFINE_DPM_OUTPUT is the best way. However, when compiling the "Melting Index Along a Particle Trajectory" example in Fluent UDF user guide, I always met the compile errors, like "parse error", "structure reference not implemented", or "sprintf: undeclared variable", etc. Do you have any experience on it ? I really appreciate your info.
Thanks,
Xubin
Old   October 25, 2001, 09:09
Default Re: problem on DEFINE_DPM_OUTPUT
Wolfgang
Hi Xubin, Isn't it enough for your problem to activate the "Step by Step" Report Type in the menu "Particle Tracking"? Than you will receive a file with all particle positions and velocities. You can import these data into Excel.
Wolfgang
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
