Double Precision
Old   October 4, 2001, 15:44
Default Double Precision
Ugur
Hi;
I have a question. Is there any way to use double precision real numbers in user defined functions?
Thanks...
Ugur
Old   October 5, 2001, 04:33
Default Re: Double Precision
Anthony Wachs
I am wondering if I have clearly understood your question. According to me, simply replace :
real x;
by :
double x;
Is that what you would like to know ? I apologize in advance if my answer is too trivial. If it is the kind of anwer you expected, I hope it might help...
Best regards,
Anthony
Old   October 5, 2001, 14:58
Ugur
Yes, you gotteh question correctly, does double work in interpreted UDFs? Or, when your case in double precision,even if you define as real is it single or double precision. I mean, does precision of the case affect the precision of the UDF? Thanks...
Old   October 9, 2001, 04:32
Greg Perkins
You don't need to do anything. Just declare your variabes as
real x;
you will find that when you use double precision the Fluent header files define
#define real double
while for single precision Fluent defines
#define real float
Thus if you always use real you should have no probs.
Have a look at the .h files in the /src folders under Fluent.Inc/fluent5.x/ etc.
Greg
Continuing User Defined Real Gas Model issues aeroman FLUENT 6 April 8, 2016 03:34
Parallel User Defined Real Gas Model aeroman FLUENT 4 July 1, 2015 06:09
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
what's wrong about my code for 2d burgers equation morxio Main CFD Forum 3 April 27, 2007 10:38
REAL GAS UDF brian FLUENT 6 September 11, 2006 08:23
