secondary phase velocity with ASMM ????
Old   November 8, 2001, 11:07
Default secondary phase velocity with ASMM ????
fawzy
I m using the algebraic slip mixture model in stirred tank and i want to use the secondary phase cell velocity in some UDF. How can i access to its name (argument)
Old   November 12, 2001, 05:42
Default Re: secondary phase velocity with ASMM ????
Isa
Hi!
You didn't answer my querstion before on the dispersed phase volume fraction.
I know you said that you are using ASMM, but my question was relating to validity of the use of ASM. To be able to use ASm with any accuracy at all, your solids (disperse) VF will have to be very low (< 1%).
What is the physical disperse VF of solids that you have?
Old   November 12, 2001, 12:28
fawzy
Hi Isa i have answerd you last week see "multiphase in fluent 5.5" my answer was :
"I don't use dispersed solid phase. I use the ASMM for gas sparging in mixed tank. So it is no limitation for the gas volume fraction as gas density << primary fluid density. See always "On mixture model for multiphase flow", Manninen & Taivassalo, VTT energy, VTT publications 288. available via the web in pdf format (67 pages).
Have you any idea about my question ? thanks
Best regrads fawzy "
How about my question ?
thanks
Old   November 19, 2001, 04:43
Isa
Hi!
And my question was:
'I know you said that you are using ASMM, but my question was relating to validity of the use of ASM. To be able to use ASm with any accuracy at all, your solids (disperse) VF will have to be very low (< 1%)'
There is no point in answering your question about ASM if it is not an appropriate model to use.
There's no point in using a model just because its easier. If it is known, that the model is inappropriate (i.e. will give completely the wrong answer as it doesn't incorporate half the physics), then why are you doing the modelling?
Therefore, I ask again, what is the physical volume fraction of the solids?
Old   November 19, 2001, 11:40
Default Re: ASMM
fawzy
I dont 't use solid but gas as dispersed phase. I don't use dispersed solid phase. I use the ASMM for gas sparging in mixed tank. So it is no limitation for the gas volume fraction as gas density << primary fluid density. I know that when density of primary phase is smaller than the secondary phase density ASMM is only applicable for low volume fraction (less than 10% ) and size of solid less than 50 um.
It s not the case in my problem where i use water as continuous phase ans air as secondary phase
velocity components of dispersed phase in posdat.f kube STAR-CD 3 November 24, 2010 01:41
Velocity components of dispersed phase in the subroutine postad.f kube Siemens 0 March 16, 2009 15:30
please help to patch volum of secondary phase VOF zidouni FLUENT 1 February 27, 2008 05:46
how to patch a volum of secondary phase using VOF zidouni FLUENT 1 February 26, 2008 02:18
How much the value of secondary phase at the inlet KBS FLUENT 2 May 31, 2006 10:18
