January 15, 2002, 00:34 |
defined order of react ???
Today , i would like to simulate two mixtures that flow through the different channel respectively . First mixture(include hydrogen ,water-vapor)flow in top channel. second mixture (include oxygen , water-vapor , nitrogen)flow in below channel . but two channel contact together . the surface area is wall between top channel and below channel . i want to ask how to defined the order of react of species(total four species )inside in Fluent 5.5 solver. Defines/Materials/Mixtures species panel
January 15, 2002, 01:27 |
Re: defined order of react ???
You should define at least 5 species.
H2O, N2, O2, H2, CO2 Maybe you should define more specises for intermediate species. For one step reaction model, you can refer the reaction parameters from the DEFINE --> MATERIAL --> DATABASE --> 'MIXTURE MATERIALS, Hydrogen-Air --> REACTION MODEL --> VIEW It's fairly simple one-step reaction model. And you can also use 'MF(Mixture Fraction)/PDF Model. For more information, I think that you should study, because it's fairly difficult to fully explain the modeling strtergy of combustion simulation because combustion itself is fairly difficult. Sincerely, Jinwook |
January 15, 2002, 03:48 |
Sorry, you don't need CO2.
2nd order upwind vs 2nd order upwind!!! | Far | Main CFD Forum | 7 | March 14, 2013 12:29 |
1st order vs 2nd order | ken | FLUENT | 8 | March 14, 2013 03:43 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
How to defined the order of react ?? | kevin | FLUENT | 0 | December 18, 2001 08:35 |
defined order of react ???? | joby | FLUENT | 0 | November 27, 2001 01:00 |
