Help! UDF Compile Error
Old   January 15, 2002, 08:37
Default Help! UDF Compile Error
Michael
I am now developing a new drag model by using the UDF. This model needs the gas variables in the location of tracked particles. But I always met the
Error" Reference Structure not implemented" in the following lines
cell_t c = RP_CELL(&p->cCell);
Thread *t = RP_THREAD(&p->cCell);
tf = C_T(c,t);
(My own UDF code is attached below.)
Then, I try the example in Fluent Manual. Even for
#include "udf.h"
DEFINE_DPM_OUTPUT(melting_output, header, fp, p, thread, plane)
{ real d;
d = P_DIAM(p);
d = p->state.diam;
The error" Reference Structure not implemented" still shows up at the line of
d = p->state.diam;
It seems that something wrong with the structure decalaration. I really apprecaite it if you once experienced similar problem and can give me some advices.
Michael
#include "udf.h"
#include "surf.h" /* not included in udf.h so must include here */
/* include surf.h for macros: * RP_Cell() & RP_Thread() */
#define GAMMA 2077. //He
DEFINE_DPM_DRAG(udf_drag_force, Re, p)
{ real xmach, tf, tp, vf, vp, rho, xmu, dp, Cd;
real vsound, tr, sr, gamma, Cdone, Cd175;
real drag_force;
cell_t c = RP_CELL(&p->cCell); /* Get Cell and Thread from */
Thread *t = RP_THREAD(&p->cCell); /* Particle Structure */
tp = P_T(p);
dp = P_DIAM(p);
tf = C_T(c,t);
Cd = ...; /* equations for computing Cd */
drag_force = 18.*Cd*Re/24.;
return (drag_force); }
Old   January 18, 2002, 16:24
Default Re: Help! UDF Compile Error
sivakumar
hi,
are u trying to use interpreted UDF? if so u can't use structure variables with it. u will have to use the compiled UDF to use these variables. if not,im sorry, i dont know why. all the best. siva
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
[Netgen] Installation of Netgen in SuSE Linux 92 edvardsenpriv OpenFOAM Meshing & Mesh Conversion 23 January 16, 2009 06:12
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 05:07
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
