Mixing plane geometry definition
Old   January 18, 2002, 07:16
Default Mixing plane geometry definition
Hbet
I am confused about the mixing plane geometry definition in Fluent. As you know there are 2 options : Radial and Axial. If the mixing plane is a cylindrical surface with an axis coincident with the axis of rotation, is this a radial mixing plane ? Or, if the mixing plane is a flat surface normal to the axis of rotation is this an axial mixing plane ?
The users manual P.16-30 states that: A Radial geometry signifies that the information at the mixing plane interface is to be circumferentially averaged into pprofiles that vary in the radial direction. This is the case for axial-flow machines, for example.
Could anyone enlighten me on this issue, and help me to have a correct understanding of the mixing plane geometry definition.
Thanks
Hbet
Problem with Mixing plane Mitpostdoc FLUENT 0 July 26, 2011 14:31
Mixing plane for centrifugal compressor Mitpostdoc FLUENT 0 March 24, 2011 17:27
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 12:43
Definition of Plane pointer Julian K. FLUENT 0 January 5, 2009 10:24
Error in flux at Fluent´s mixing plane calculation ales FLUENT 0 February 9, 2005 04:48
