January 21, 2002, 11:51 |
significance of viscosity ratio
During iterations running the turbulent model I am regularly getting the report turbulent viscosity limited to viscosity ratio of 1e5 in xxx cells. I cannot find in the Fluent manual what the viscosity ratio is. Is it simply the definition of viscosity ie ratio of shear stress to shear rate? What does this warning signify in the model, are there common causes which lead to this problem?
Turbulent viscosity ratio | Balaji | FLUENT | 5 | May 27, 2014 03:47 |
pressure eq. "converges" after few time steps | maddalena | OpenFOAM Running, Solving & CFD | 69 | July 21, 2011 07:42 |
Turbulent viscosity limited to viscosity ratio... | Cyril | FLUENT | 8 | February 7, 2006 20:34 |
On limiting to turbulent viscosity ratio! | varghese | FLUENT | 2 | November 15, 2003 08:56 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
