Reversed flow in ###faces on face ###
Old   March 1, 2002, 11:38
Default Reversed flow in ###faces on face ###
TOM
What does "Reversed flow in ###faces on face ###" mean while Fluent is calculating (Iterating)?
Old   March 1, 2002, 11:43
Default Re: Reversed flow in ###faces on face ###
Phil
if its reversed flow on one of boundaries you have set as an output from your model: outflow, pressure outlet etc it means that in some of the faces on that boundary flow is entering the model rather than leaving it.
reversed flow on faces limited in 500 cells in region outlet alan81 Siemens 0 May 15, 2011 12:42
Error to re-open fluent case file J.Gimbun FLUENT 0 April 27, 2006 08:42
DPM Reversed Flow Hendawi FLUENT 2 June 5, 2002 05:01
reversed flow vineet birman FLUENT 2 May 8, 2002 00:58
