channel with wire mesh simulation?
Old   April 16, 2002, 03:27
Default channel with wire mesh simulation?
rslgp
hi cfd friends,
I have rectangular channel in that wire mesh(Mesh contains uniform diameter holes) is placed perpendicualr to the direction of flow. can this condition be simulated in fluent 5.5?
Thanks in advance.
bye
Old   April 16, 2002, 12:46
Default Re: channel with wire mesh simulation?
Evan Rosenbaum
You could use a porous medium to simulate the momentum sink that occurs across the mesh, but it won't capture any velocity perturbations that might occur in the flow field perpendicular to the primart flow direction.
Old   April 16, 2002, 13:03
rslgp
hi Evan,
Thank you for reply. i am interested in the K.E.Dessipation behind mesh. Hence will it give resonable value of E. waiting of reply.
Old   April 17, 2002, 12:40
Evan Rosenbaum
The porous medium (or porous jump) models will not give you the right turbulence effects. If you want to have it right, you would have to write some sort of UDF.
Old   April 17, 2002, 14:01
rslgp
thanks for useful reply bye
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
mesh generation for in-cylinder fluent simulation hennas ANSYS Meshing & Geometry 2 May 31, 2011 15:08
[mesh manipulation] local mesh refinement at channel geometries Kr_kim OpenFOAM Meshing & Mesh Conversion 6 February 9, 2010 14:25
Replacing mesh while running a simulation akultane CFX 1 November 15, 2009 13:46
