Real Gas Model
Old   April 24, 2002, 11:17
Default Real Gas Model
MJK
Hello dear Fluent Users,
A friend asked me a question about the previous versions of Fluent, i.e. releases before the curret 6, if:
Do the previous releases support real gas computation? If any one can help in this regards that would be so helpful.
Thanks
MJK
Old   April 24, 2002, 12:31
Default Re: Real Gas Model
LW
Yes, F5 has non-gray DO radiation model. But it depends on what you know about the "real gas" - absorption bands and coefficients, etc.
regards
LW
Old   April 28, 2002, 04:25
MMA
Thanks for your reply. I am not modeling radiation. The following lines are copied from a ver. 5.23 fluent session
/define/user-defined> compiled-functions function-hooks real-gas interpreted-functions fan-model
/define/user-defined> rg use real gas? [no] y Invalid switch - "realgas". select real-gas data file [""] "r11" Invalid switch - "realgas".
As you see I get Invalid switch answer in spite of the fact that real gas option is among the choices. I'll be grateful for your help.
MMA
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 04:24
Using real gas models in Fluent neville FLUENT 1 June 5, 2012 05:54
how to hook this udf shanu FLUENT 1 August 26, 2011 10:48
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 05:08
