Question on starting multiphase simulation
Old   April 26, 2002, 19:28
Default Question on starting multiphase simulation
Derek Jing
I will use the Eulerian model of FLUENT 6.0 to simulate my problem. However, when I open the menu of Define>Models, I found that the menu for "Multiphase" is in gray, which means it can not be used. Could you please tell me why this happen? Thank you very much.
Old   April 26, 2002, 19:36
Default Re: Question on starting multiphase simulation
Derek Jing
Sorry, I already found the answer. Thanks.
Old   April 30, 2002, 10:32
Yvonne
Hi Derek!
I'm also working with the Euler-Euler-model. Do you like to share some problems..or better solutions? At the moment i can just tell that the Euler-euler.model in my case ignores walls (it looks like the flow just goes through the wall, very strange). What about you?
Yvonne
ANSYS CFX volume fraction definition for multiphase simulation juliom CFX 11 January 24, 2018 05:32
Volume fraction in multiphase simulation juliom CFX 2 July 30, 2011 08:26
Multiphase Simulation giving wrong results niazaliahmed STAR-CCM+ 2 June 17, 2011 00:41
Starting a 3D URANS simulation from a converged 2D URANS simulation Josh Main CFD Forum 2 June 4, 2011 20:32
multiphase simulation floating point error vidhya Main CFD Forum 0 April 10, 2011 23:18
