Postprcess of FIDAP
Old   May 19, 2002, 10:52
Default Postprcess of FIDAP
jwt
I had done a caculation of flexible pipe, and want to show the distortion result of pipe in the FIPOST. How to do it? Please detail.
Old   June 3, 2002, 18:09
Default Re: Postprcess of FIDAP
Jaydeep Kulkarni
You can use the command "mesh" to see the distorted mesh or use contour(dx/dy/dz) commands to plot the contours. If the problem is transient, then you can issue the "movie" command followed by one of the above commands.
Old   June 5, 2002, 04:03
jwt
Dear Jayk: Thank you for your reply.I had seen my result use your method,but the meshs were distorted too much.I tried to change several scale factor,but no any change in the mesh window.Do you know how to do ? Thank you in advance jwt
Old   June 10, 2002, 14:09
Xiaoming
click 'View', then click 'Pan/Zoom'.
Old   June 12, 2002, 20:01
sam kashan
Wonder if any knows how to postprocess the time avareged pressure coeff obtained using a transient simulation for a flow past cylinder. thanks
Fidap to Fluent Ravi FLUENT 3 July 10, 2008 13:31
user_sub FIDAP doesnt work semetay FLUENT 3 July 22, 2006 19:51
2D Transient flow using Fidap Young FLUENT 1 July 2, 2004 12:02
2D Transient flow using Fidap Young FLUENT 0 July 1, 2004 00:26
Variable Density - Free Surface with FIDAP Vitaliy Pavlyk FLUENT 7 May 2, 2000 15:56
