Turbulence model for Transient Pipe Flow Modeling
Old   June 7, 2002, 12:15
Default Turbulence model for Transient Pipe Flow Modeling
Brian
Concerning transient modeling of a high pressure blow-down and supersonic flow in small diameter tubes (approx 0.5 inch), has anyone found a way to overcome the extremely small timesteps required by high speed flow with a fine grid?
Has anyone had good sucess with a particular turbulence model for problems of this type?
This is a very highly turbulent flow problem. The pressureization is coming from a pyrotechnic charge that pressurizes a chamber up to 10,000 psi and then vents to ambient pressure. Any recommendations for K, e in the high pressure tank?
I'm running Fluent V 6.0
thanks
Mixture model - pipe flow Aly FLUENT 10 June 21, 2010 13:50
question about turbulence model selection and sensitivity karananand Main CFD Forum 1 February 26, 2010 04:41
Turbulence in pipe flow. JM Main CFD Forum 3 February 2, 2007 08:18
turbulence model for oil flow thr' small gap carno Siemens 2 August 31, 2005 08:12
pipe flow with turbulence Yanhu Main CFD Forum 1 May 30, 2001 09:39
